Roadhump
Time you enjoyed wasting was not wasted
- The flatlands of South West Lancs
Had a puncture today and stopped to fix it outside a house where the owner just happened to be a cyclist and who very kindly came out and helped, and used his track pump to inflate the tube and locate the hole. I am just a bit unsure of what to do next after listening to his advice though.
I used one of those super patches that I got from Evans Cycles to fix the puncture and it is a very thin plastic film with strong adhesive on one side. My more experienced fellow cyclist inflated the tyre to 60 psi rather than the usual 100 as he said the patch would likely give way otherwise. I cycled the 9 miles home no problem, but am now wondering whether to put a new tube in, and also whether to buy a new tyre - we found the cause of the puncture, which was a piece of glass and managed to remove it but it is a fair sized hole and I'm wondering if it might just be best to replace both rather than risk a repeat.
I've been lucky with punctures so far and not really up to speed with them so any advice is gratefully received, thanks.
