I wasn't going to comment on this but on second thoughts I think I have to
I have said before that I don't believe the perfect wheel does exist and I stand by that statement.
I sincerely doubt that we disagree on this one.Yes, hubs and rims are not perfect in an absolute geometric sense but who cares? Are we riding bikes or entering a tolerance contest? Good enough is good enough. Tyres on MTBs have run-out of up to 5 mm, 10 if it has had a snakebite impact. Why then care if the runout on the rim is 0.2 or 0.5mm? The braking surface is at the disc and a bit of runout at the rim is neither here nor there. As for road bikes with their closely-spaced pads: a 0.5mm or even 1mm runout is of no consequence whatsoever.
My use of "perfect" is not 100% and I certainly don't include the design errors of the hub manufacturers when I say 100%. Rims have a little radial run-out at the weld - no wheelbuilder can make that go away with a spoke spanner, but why bother?
A perfect wheel by my definition is one that you fit and forget. It gives you close to zero hassles in terms of periodic truing (as rims fatigue they relax around the pull zone and the spokes have to be adjusted to keep the wheel true, but this is after prolonged use only), zero spokes breaking from fatigue, no spokes coming loose by themselves and, gives the user the confidence to ride hard, brake hard and load the bike should it be required. What more could we want from wheels? People obsess too much about wheels and forget that it isn't about the bike.
Now people who read this thread my think "Ahhh, here we have someone that has built thousands of wheels and he can or know how to build perfect wheels," well, I humbly disagree
Hopefully I've now convinced you otherwise.
I learnt to build wheels to a 0.2mm lateral tolerance and 0.5mm radial tolerance which is more than enough. In fact, I can now achieve a little better than that but still, that is not a perfect wheel. It's a fine wheel to ride though.
It is easy to achieve low runout on wheels with plenty of spokes and harder to do so as the spoke count decreases. But the numbers are kinda irrelevant. More important would be the shift in runout after the first 1000kms. That would be a better indication of quality. A wheel is always in transition and a smaller change over time is more important than the initial position of the rim in the truing stand.
As for the rest of the statement about the use of a tensiometer all I have to say is this, I'm with you in the general context, however, I think tensiometers are a useful tool that are used by some very reputable professional wheel builders all the time, even the great Harry Rowland. Of course these people can build great wheels without such tools but they still use them.
I don't know the great Harry Rowland or what makes him great for that matter. The fact that X or Y uses one won't sway me. Of course it is a useful tool and I'll admit that if someone is on their own building their first wheel and they are provided for a set of measures for the particular rim and spoke count they're using, it would be of great help. But that doesn't happen. For instance, let me suck a scenario out of the air. Rear wheel: Hope PROII hub, WTB iFrequency 19mm rim, 29er, SAPIM LASER spokes, 32 of them. What tension would you recommend? The dilemma is this: No (rim or spoke) manufacturer publishes those figures. Rim manufacturers publish vague ranges of tension that are not spoke count specific.
It would be better for our hypothetical student above to simply take a trusted wheel, get the tension tone from plucking and going ahead. Of course he could use the tensiometer to copy the sample wheel but that is more expensive than listening to the tone and where will he/she find the exact same wheel?
I think it has more use in factories where a certain spec is set and has to be adhered to. But, people like buying and owning gadgets. Me too.
You have the Jobst Brand book with you. He describes eloquently how to determine maximum tension. It is in the chapter on Spoke Tension IIRC. I agree that you won't want to do this each time, but it is a great learning experience and teaches you quite a bit about wheel behavior. You may also want to read about the tensiometer that Jobst designed. He designed his own one because ALL other products on the market have a fundamental error. He gave the design to his friends at FSA sometime in the 1990s and they made only 200 of them. I approached Jobs 10 years ago for the design and he sent me the CAD drawings. I then made one for myself. In ten years or more, I can honestly say I only needed it ten times. Each of those occasions was to fight a rep who wouldn't warrantee a customer's wheel because "someone overtensioned the spokes". I used it as a truth machine to cut the BS. It can be viewed on the Wheel Fanatyk website, I think. To most people this great tool would be worthless because it has to be calibrated if you want a reading. Otherwise it simply gives a measurement as deflection, in mm. But it is consistent.
Insert plenty of smileys all over the place. I'm not familiar with this forum program yet.
