Andy in Germany
- Rottenburg am Neckar
I decided that as I seem to be moving a speeds which could charitably be described as “geological” I may as well make some landscapes.
I’m assuming the builders of this low budget aerodrome decided that if you want an elevated building, the cheapest option is to use an existing hill, instead of making an expensive tower out of wood. In keeping with this philosophy I made the ‘landscape’ itself from old cardboard offcuts, before smoothing things down with clay and slopping a gooey mix of wood glue and paint over the top.
The hole in the landscape is a solution I’ve seen used by some makers of tabletop games. As collections build up, it seems you end up with a number of buildings, not to mention vehicles, sea monsters and apparently mandatory cosmic death rays. As these tend not to stack very well, one way to save space is to hang them up instead of letting them take up shelf space. I just have to work out how to cover the hole effectively.
