Punkawallah
“Throw the Third Switch, Igor!”
I work on the ‘3’ Rule’. If it looks OK from 3’, It’s good enough :-)
Try not to do the cut in one go. Make two passes with the blade drawn slowly.Starting the next project.
This is loosely based on the Robin Hood Hotel photos posted here by @EltonFrog; it will look somewhat different because the original would be huge and an awkward shape:
Notice use of filler to hide inability to cut and file straight. Next stage is finishing the detail...
Could you build a model of something akin to this?
And would it fit in with what you've built so far.
I think @Andy in Germany has already built something similar...
You'll have noticed that the same part is also the only brake shown on the machine.Indeed, with steam power...
I like the one @classic33 posted though, especially the annotation "Steering and control wheel not used in high speeds"...
