I'm running the same tires as you at the same size; at 180 LBS (+24 lbs Bike/equip)
A Excel.docx based calculator says around 32 PSI front and 41 PSI rear - I personally run 34 PSI at the front and 42 PSI rear at that weight range (Split 45/55 weight distr)
For heavier riders at 210 LBS @ 24 Lbs bike equip; it goes to 37 F and 47 R. - Even if you're quite heavy in reality the PSI increase is not dramatic; I Believe that this calculator was aimed at the 15% recommended tire compression method, so it's not the minimum/max psi to ride.
As
@MacB said, in reality while there is supposed to be a negative to running low PSI we do not feel it as much as we do when we run Too high psi. - 42c isn't a 25-32c tire, don't need to rock 'em hard anymore.
Edit: if you know your weight + bike weight + your weight distribution (45/55 or 60/40) then reply to me and i'll give you a more accurate PSI you could try.
