cyberknight
- Land of confusion
At 77 a clipless moment could be much worse. My dad fell over in ice and finished his cycling career. Risk vs reward is a personal calculation.@Saracenlad I've ridden clipless for 20+ years and wouldn't go back but I would advise against making the change.
I'm 10 years younger than you but very aware things take longer to heal these days. Initially you will fall off and I'd respectfully suggest at 77 the risk of breaking bones is too great to attempt the change. A break could mean what? Six months off the bike?
I agree entirely. We hear too often of older people falling at home and breaking a hip, leg etc. To go clipless at 77 is frankly asking for trouble.At 77 a clipless moment could be much worse. My dad fell over in ice and finished his cycling career. Risk vs reward is a personal calculation.
What you have stated is what you might expect.to be pernickety they are called single sided as one side is clipped with a flat on the other , double sided means it clips in both sidesonly raising it just in case the OP goes and buys the wrong sort due to confusion
My experience is the opposite. I have been riding "double sided" SPDs for 20+ years and they are that. Double sided with the same fittings on both sides. I see this as one of the major advantages of riding SPDs on a road bike.What you have stated is what you might expect.
But it is not what you get in reality. The previous poster was quite correct. If they are described as "double sided" it means clips one side, flat the other.
I've never quite understood why they are described that way, they should be as you say, but they aren't.![]()
It isn't what I am seeing advertised that way.My experience is the opposite. I have been riding "double sided" SPDs for 20+ years and they are that. Double sided with the same fittings on both sides. I see this as one of the major advantages of riding SPDs on a road bike.
I don't disagree with the ads obviously but if I walk in to my LBS and ask for double-sided SPDs they will have the same fittings on each side. Shimano.It isn't what I am seeing advertised that way.
If I put "double sided clipless pedals" into Google, these are the first 4 results( the boardman ones being what I currently use) .
https://www.halfords.com/cycling/pe...O-fdCYr8ldSDbYBQel6XnnpvfgVYN-kxoCpR0QAvD_BwE
https://www.planetx.co.uk/i/q/PEJOB...RCzlsTVlDarZdDKdtK_mTRoCmfYQAvD_BwE#PEJOBDMTB
https://www.tredz.co.uk/.Shimano-PD...-viIluYC0vnNUWpZqjFJthYSoq9ZKoBoCdk4QAvD_BwE#
https://www.decathlon.co.uk/p/100-d...h0sm8YASTvPm14zYZ3RoCeeQQAvD_BwE&gclsrc=aw.ds
i think your confusing double sided and duel sidedWhat you have stated is what you might expect.
My interpretation of "double sided", is that you can use either side for pedalling, as opposed to the old Lyotard platform pedals
or the modern look keo pedals.
Perhaps pedals with different fastenings on each side should be called "double sided/dual function"
I'm not confusing anything.i think your confusing double sided and duel sided
you know what im not going to argue its not worth the hassleI'm not confusing anything.
I was in fact quite confused by it myself when I first started looking for that type of pedal. I kept seeing "double sided" and was thinking "no, I want one side clips". It was only when I looked closer at what was coming back that I realised they were what I was after.
