Racing roadkill
No. A material can only absorb energy by deforming, which is what the metal in a car's crumple zone is designed to do, or by cracking. If your CF shell deforms, then it'll be deforming into your skull, which I suspect isn't a desirable outcome. Except of course CF doesn't deform, it's brittle so cracks. But not in the way that expanded polystyrene foams do, by forming any thousands of microcracks which create the new surface area that absorbs energy. No, it'll shatter into large, sharp shards. Which absorb very little energy, but will gain considerable kinetic energy of their own. Not the sort of thing you really want to have spinning around your head and eyes...
Of course, it's also possible that they don't want to test it against a tougher standard because they know it won't pass. After all, the amount of energy any structure is capable of absorbing can be calculated by anyone who can use an engineering finite element model analysis package.
20 years ago,pre preg Carbon Fibre behaved like that, not these days it doesnt. It disintegrates in a very controlled and confined manner. You won't see shards flying off, unless it really is a catastrophic super high energy event (think explosion, or Formula 1 car body work Kinetic energy levels). These materials are designed to act more like the deformable nose cone structure of an F1 car / aircraft. as long as the manufacturing process has worked (lay up, cut and form, autoclave, and finish) you won't see the armageddon-esque disintegration and flying shards of CF.
, a good place to look, I'd checked the recumbant area, I hadn't found anything there.
