GrumpyGregry
Here for rides.
My Ritchey hubs, which are DT Swiss clones really, have removable end caps and I'm told, if one can find the parts, one can convert similarly.Pro 11 Evo certainly are. You can get QR, 9mm thru axle(I run a 9mm thru-axle QR on mine on standard QR dropouts) , 15mm and 20mm converters for the front, and for the rear you can get a standard QR, 10mm thru-axle QR and a bolt thru that needs a a different converter. They are literally end caps that pop out and refit to fit the different axle shape. The rear bolt thru needs a more expensive converter kit.
Am I right in thinking a 9mm thru axle QR is a solid axle with 9mm QR which replaces the hollow axle and QR?
