slowmotion
Quite dreadful
- lost somewhere
Mine works fine thanks and no moving parts to break...[/USER]
Yes, I suppose if it doesn't work it must be hard to break.
Eh?Induction hobs are more controllable than gas hobs
Miss Goodbody has an implement similar to that., But hers is shorter, squatter, made of rubber, and makes a buzzing noise.Nah, you want a steel, it's real!
You'll be telling us it has a regulator on the end of it too. Does she have a nice worktop with a scribed butt?Miss Goodbody has an implement similar to that., But hers is shorter, squatter, made of rubber, and makes a buzzing noise.
Blimey loads of views to read through here
I`m now tied between induction and gas, my current cooker is halogen and although I`ve got used to it it`s a bloody nightmare, pans take ages to boil and once they do there`s no stopping them, the contents either burn or boil over!
Mixed reviews on the worktops and some good points, might re-think that and see what else is out there.
Just another quick question for the kitchen fitters here - does a double "built under" oven need a cabinet? I`ll be using the 600mm space where my cooker is now, but not sure if these ovens need a cabinet or just stand on their own feet which are then hidden by the plinth?
I did yes, but my kitchen isn`t big enough to take one, it`s only 11` by 7` so would probably take up most of the room!Have you considdered a range oven?
Free standing and some good quality ones about
Oh really? Rumour has it her chopper is a thing to behold... @Fnaar is often found in a quandary. Right now, he needs to be found in a quarry, and get speccy's worktops sorted out.You won't get me near Ms Goodbody....
Once upon a time she used to say "cor Ian" but now she's for Mica...taste change. That's why it's good to have a slate worktop - it can be wiped clean. Ooops! the topic has just fallen off the edge...sorry. I blame the fnaarster.Are you suggesting that Ms Goodbody is really a pre-op Mr Goodbody?
Range cookers like Aga and shïte are great if you're a posh middle-class nobber, but for practicality and cooking decent stuff they're rubbish. Granite is still really heavy.
