Profpointy
As already stated, Granite is a job for the professionals, gluing the mitre joints and cutting cut outs for hobs etc.Normally you have an undermount or a butler sink.
Edit, The draining board are also generally machined in to the tops which makes granite tops look great from my angle.
I didn't bother with the draining board slots for my granite. The point of a draining board is so water doesn't damage a laminate or wood top. Granite is utterly waterproof so doesn't need protecting. Admittedly water then pools up a bit but you have the flexibility of extra worktop or dish rack according to needs. And saves a couple of hundred quid.of slot cutting on a bill which is already quite enough thank you.
