Ajax Bay
- East Devon
This ^^^^^.Your LBS is highly likely to have one in their spares box.
Mercian cycle or sjs cycles might be able to help but i have seen what looks right on mercian and it was £30, might just be easier to just get a compatible second hand replacement.Thanks for replying cyberknight, I messaged that seller on ebay and he told me my image was 'the RD-RE012 adjuster that Campagnolo no longer produce. It is a smaller diameter that the newer RD-AT115 & RD-DA004.', but even when I googled RD-RE012, it still doesn't look like the one that's fitted at present, which I've broke.
I wonder if the RD-AT115 would actually fit.
You need to set this up so that the cable is in tension even on the smallest sprocket and that you have it indexed so that when you click once the RD cage lines up with the smallest sprocket, and when you click again it shifts to the next smallest. Then when you've clicked 7 times in total (8 speed shifter) you'll be in the largest sprocket (of the 7). Limit screws should be adjusted as normal.
Edited to add: In operation (when adjusted as I've described above), when you click down the cassette, on the 6th click you'll engage the small sprocket. On the seventh click the chain will stay on the smallest sprocket because the lower limit screw will keep it so aligned. Moving up the cassette, nothing will happen on the first click: a second one will take you into the second smallest sprocket.
the bike store owner told me he'd had some troubles indexing the gears as the cassette (9 speed), didn't match the shifters (I think he said 8 speed), and it would cost more than the bike's worth to put right, but he'd done his best on it
As it transpires, the guy in the shop was dead on the money. The cassette did not match the shifters, and it would 'cost' to 'put right'.The guy in the shop was talking out of his arse,
Plenty of good, reliable LBSs and those that work in them around.
The parts (ergo and RD) are quality parts - their performance will not deteriorate with age.not perfect, but don’t think it’s going to be on a bike this old). However there’s one shift I can’t get right, coming down from the big ring at the back, while on the big ring at the front, the chain catches on the ring it should it be coming off and completely jams.
As you say later, you should never be there. Once you get above the middle of the cassette on a hill, bite the bullet and change down at the front (if necessary double change by dropping to the next smallest sprocket at the same time). You haven't got loads of gears so need to make the most of them.
