- Shrewsbury, Shropshire
What @JhnBssll said.
What I do is set up the high and low stops first then put it into 4th or 5th (on an 8 speed) and adjust so that the top derailleur pulley is lined up with the appropriate gear. Indexing should then be pretty much there and will likely just want fine tuning to finish. If you haven't got a stand then an assistant to hold the bike with back wheel off the ground will make this easier.
