700c to 26 inch wheels, is it possible ?
desperion
Thanks everyone for your input, which has been very instructive and which has cleared up the remaining few niggles on the subject. I appreciate all your help.
Glasgow
@desperion, for what it's worth, you're supposed to slide out of the saddle, jump back on.
Calling @Rickshaw Phil for a cut and paste of his excellent optimal saddle height advice :smile:
Overconfidentii Vulgaris
:hello: You called?
I'm well known for having a bee in my bonnet about this so for what it's worth, here is the cut and paste ;):
The method I usually suggest to get a good starting point is to set the saddle height so that your leg is straight when sat on the saddle with your heel on the pedal at the bottom of the stroke. It should then be about right when pushing the pedal with the ball of the foot and can be fine tuned to suit you from there.
There are other more technical methods available but this is a nice easy one to get started with.
Sara_H
Hi Citius,
I am aware of the saddle/pedal distance, just thought smaller wheels would make life easier but thanks for reminding me
How fat is your saddle? Sometimes swapping a fat cushioned saddle for a non padded saddle can make all the difference.
This is what we did with a bike someone gave my stepson, it was just a bit too big, swapped the saddle - he was fine.
Profpointy
Do the maths. Don't rely in guestimates and vague terms.
The circumference of a 700C wheel with 25mm tyres is approximately 2105mm. The circumference of a 26" wheel with a 32mm tyre is approximately 2010mm.
It is a matter for 2PiR but there are plenty of online calculators that will find the Radius of the wheel for you. Once you have the Radius, you can compare and you'll know exactly how much closer to terra firma you will be with smaller wheels.
umm circumference?
Profpointy
What am I, ummmm, missing here?
the question was about anout height from the ground so multiplying by 2-p isn't adding any clarity.
Loch side.
Yes, but I did suggest you find the radius. The difference in radii between the two wheels will give you the drop in pedal height above the ground. The reason I started out with circumference, rather than radius is because this information is freely available on the chart you set your bike computer from. In other words, given info helps to calculate the radius which leads to the difference in height.
Am I having a Monday Thursday or are you?
Andy_R
Hard of hearing..I said Herd of Herring..oh FFS..
County Durham
...or you could just use a tape measure from the centre of the axle....just saying.....
Profpointy
and to the OP - i suggest it's a bad idea even if theoretically possible as a challenge. All sorts of things will have to be made/bodged to fit - perhaps poorly or even dangerously (brakes say), risk of pedal strike and for what? It is unusual to be able to get more than a toe down whilst sat on saddle, and if you can't do that, bike as a whole is likely too big, so smaller wheels is the least of the worries
Andy_R
County Durham
or you could invest in a pair of these:
Profpointy
my partner is after motorcycle boots a bit like that - and they're bloody hard to find with more than about 10mm lift. MC are not made with the shorter lady in mind - and a low-rider Harley looky likey is just too embarrasing
desperion
Not as fat as me :blush:
Here is a photo of a similar saddle
r saddle
