A narrower rim has enough material in it to make sure that it is safe for the forces it is subjected to. If you go and make a larger hole in that rim, it may/may not effect durability. I seriously doubt it will make a lot of difference, but I always err on the side of caution, as I'm a big guy. Also, I think narrower rims are made for presta tubes, which tend to run thinner. I like 700x23, all the way up to 700x28, but I run even 700x28s on a wider rim than that. Narrower valve-narrower rim, wider valve-wider rim. If I'm going for speed, I'm usually on 700x23s or 700x25s, with presta valves. If I'm touring, or have a load, or I'm worried about the state of roads, then I'm on 700x28s, which have rims for schraeder valves. I suppose it would depend on the state of the roads in Loovul, as well.
