50mph+ instabilty
Why is it that when I aproach 50 mph on a very steep downhill I cant pedal anymore? What I mean is when I DO pedal at that speed, my bicycle leans over dramatically to the side of the pedal stroke. Basically my bicycle is extremely unstable at high speed down extreme declines. 18% apparently but more like hardbastards pass in Cumbria, ****in ell!
slowmotion
Quite dreadful
lost somewhere
Your giant swinging testicles might be making the bike a tad unstable???
ColinJ
Puzzle game procrastinator!
Because you are trying to pedal, but you do not have a high enough gear to do it smoothly! In a 53/12 gear you would have to pedalling at about 141 rpm which is a pretty high cadence.
If you are on a very steep downhill, you should be able to hit 50 mph very quickly without pedalling at all, unless there is a headwind. I hit 55 mph on one local descent just freewheeling and that is only about 7.5%.
Cuchilo
Prize winning member X2
London
Its not the bike becoming unstable , its you . Have a go in a higher gear at slow speed and you will see what happens when you spin out . Once you are peddling as fast as that gear will let you , you start to bounce around on the saddle . Bounce around like that at 50MPH and things could get messy :eek:
sidevalve
I used to get a speed type wobble at 50 ish but I just power through it and accelerate away to a proper speed [only on the uphills of course].
GrasB
Nr Cambridge
^^ this.
Basically you either haven't got enough resistance to balance your pedal forces properly or your spinning faster than you have coordination in your muscles. Either way you wobble about.
Either way there's not much point in peddling on an upright at those speeds as is likely to be adding about 2-3mph to your speed!
PpPete
Chandler's Ford
I'd say NO point pedalling beyond 40 mph.
Concentrate instead on
a) getting as aero as possible on the straighter sections
b) getting your line through the corners as efficient as possible.
Hoever if you really want to improve your pedalling efficiency at high cadences - get yourself fixed.
KneesUp
5% down hill, no peddling = 41.3mph, 5% downhill & peddling at 150w (a nice base/active recovery power for me) = 47.9mph. That's including the aero disadvantage of peddling the bike. I'd say putting power in at 40mph is worth it for me.
Imagine how much faster you'd go if you hadn't sold the bike :smile:
140 rpm (52/11 gearing 700c wheels @ 48mph) is beyond me I think.
GrasB
Nr Cambridge
Sold which bike? The one I did the calcs for I rode this morning.
52t? That's middle ring territory. I run 33/48/70 with an 11-30 cassette on a 559x28 or 622x20 rear tyre depending on my mood... that's 100km/h or 107km/h at 135rpm in top gear (my maximum sustained speed rpm)... oh sorry you're on one of these inefficient up-wrong contraptions :laugh:
