Oh Wow. Super pretty.Felt a bit like autumn this evening, what better time for a bit of racering about on the old racer.
Especially with a pair of these bad boys..
Hope it doesn't lean too much to the rightFelt a bit like autumn this evening, what better time for a bit of racering about on the old racer.
Nice old lights and very nice bike if you replace the bulbs with leds the batteries will last a lot longer.
@Colin_P looks good , worth the wait ?
Hope it doesn't lean too much to the right![]()
Doing up the Revell mixte, I had a similar problem, except it was the extra stay that was fouling. @All uphill sent me some big washers, and that solved it neatly.The only downside and due to frame clearances is that I cannot use the small eleven tooth cog at the back (not that I'd use it anyway LOL).
There's certainly not a lot of space on the Revell. I think someone had spread it before me, a 130mm road wheel fitted easily.There simply isn't room back there for the chain on the small cog, the rear end was made for a narrower wheel. I do appreciate the advice and suggestion though.
