1971 Carlton Continental restoration project
Mad Doug Biker
Just a damaged guy.
Craggy Island
I do like those green mudguards. I took the black/dark grey ones off my Dad's BSA before it was sent to The Bike Station, so I do have something similar at least, albeit not the same colour.
I suppose that if push came to shove they could be stripped down and repainted if anyone is really stuck.
Spokesmann
Spokesmann
Keeping the Carlton and Sun names alive...
Plymouth, Devon
The mudguards are Bluemels Sprint Veloce. They are very hard to get hold of these days.
Spokesmann
Spokesmann
Plymouth, Devon
A day off today meant I was able to get on with sorting the stuck cotter on the drive side. This turned out to be really jammed tight and I mean tight, bigger hammers and drifts made no impact. In the end I resorted to cutting what was left of the threaded shank off and then drilling out the inner part. After much swearing, drilling and banging the remains of the cotter finally dropped out. Whilst taking break from the cursing I was able to get on with degreasing, cleaning and giving many the components an initial polishing. The grime on the machine has protected the items quite well. I'm very pleased with the Svelto rear mech and the Weinmann 730s.
The Wrights W3N saddle is responding well to daily doses of Proofide and the frame has had an initial degrease and wipe down. I'll give it a light application of T-cut in places.
I'm fitting new cables, brake blocks, outer cables where needed and a new front mudflap. Ive decided to replace the headset collar nut and front lamp bracket as these were quite pitted.
Still much to do but the machine is looking better for it. More soon.
The source of much swearing...
Spokesmann
Spokesmann
Plymouth, Devon
Made a little progress today, refitted forks with new grease, fitted rear mech and sorted some new ribbed cable. Fitted new mud flap after cutting the old cracked one away. Made a start on degreasing and cleaning the rat trap pedals. One minor problem is the BB spindle, after regreasing and fitting I find the new chainwheel won't fit on, so Ive ordered a 138mm BB spindle to give the extra space/clearance I need. Made a start on degreasing the large flange Normandy hubs. Still waiting for a few spares to arrive. Apart from toe clips, a Carradice Barley saddle bag, everything else will be as it was on this bike when it first left Worksop back in 1973.
Spokesmann
Spokesmann
Plymouth, Devon
Out all day yesterday meant no work on the Continental. This morning Ive been mostly tidying the old rat trap pedals. These things always get a beating... Ive fitted new Christophe white leather straps and medium MKS toe clips. Im waiting for a few more bits to arrive yet, so far accessories and new parts have nearly come to £90. Ive refitted the front mud guard now and also treated the the machine to one of my favourite Velo Orange ping bells.
Fun with wheels next...
Mad Doug Biker
Just a damaged guy.
Craggy Island
I'll need to see what my Dad's are, they are quite similar looking..... Which means they will be something else entirely! :rolleyes::laugh:
I went out, cleaned all the (cira 20 year old) crud off them and found no lettering, other than Stumley Archer written on the rear reflector.
I also found out they are black, not grey!! :laugh:
Spokesmann
Spokesmann
Plymouth, Devon
Haven't been able to do much today due to other pressing matters. Ive fitted the new 138mm BB spindle and this works fine and gives me the clearance I need for the back of the chainwheel from the fixed BB shell cup and also the space required between the teeth and the RHS bottom stay. Fitted a NOS lamp bracket and also loosely screwed on a new NOS threaded lock collar on the steering head. Once the rear wheel is restored I can build the bike up and bring it inside the house for final fitting out.
Spokesmann
Spokesmann
Plymouth, Devon
This is just about finished now. Hopefully Ill get a chance to give it a test ride on the weekend to iron out any small problems.
I took a few quick images last night after finishing the build and fitting bar tape etc. This is as near as I can get this bike to the original spec it was back in 73. You can see why these bike sold easily in the 70s. Carlton knew how o build a classy machine - even an entry level machine such as this.
Paint is all original, there are some marks/patina!
raleighnut
Lovely job :becool: I would have been tempted to try and get a double clanger on the front, not original to that particular bike but there was a 10 speed version and the cable stop is there. (my knees are no longer 73 spec and I won't get them rebuilt) :whistle:
