Yellow Saddle
- Loch side.
So not based on any fact or on usage of said 11 speed groupsets?
This open and honest review says it all, particularly the Summary after each mini review of components:
http://road.cc/content/review/133585-shimano-105-5800-11-speed-groupset
I read the review and see nothing there that would contradict what @Appolonius said. Basically, those two overviews are expansive press releases with an odd comment thrown in. The one or two value judgments in there are meaningless, particularly the 10% quote on brake improvement. The only time the "reviewer" mentions the chain is to say something to the effect of "the XYZ coating seems so far to resist the build-up of dirt and water" This is of course utter nonsense.
We have to consider the fact that there is a difference in the thickness of sprockets as the number of sprockets increase. This is because the available space for the sprockets has remained the same ever since 8-speed. From 8-10, sprocket width decreased. 11-speed is not much thinner (depending on the brand) but closer spaced so that the chain has to be narrower. Width is a factor of sprocket wear. However, 11-speed may well be as good as 10 because the rider may spread the usage of sprockets over more sprockets and hence dilute wear over a wider range of sprockets.
