File the burrs off that freehub while the cassette is off
I suppose not, if that's definitely the plan..No point if I'm returning it.
@S-Express just curious, did you read the thread before posting?
Well unless I'm being thick, it's definitely not an 11 speed. Looks like wiggle supplied the wrong wheelset. I'd like to know for sure, but there isn't anything I can see that shows the exact wheel model.
Definitely no spacer.
Distance looks like 35mm which corresponds to the 10 speed dimensions above.
The cassette looks spaced together ok.
But the smallest sprocket is definitely proud of the hub.
Also, some of the splines on the sprockets look worn. It's only done 2,500km.
So maybe wiggle supplied the wrong wheelset.
The only id I can see on the wheel is a barcode A516809 and a sticker saying Pro lite certified hand built PL-05138154
Any thoughts before I send it back to wiggle? I've put the original rear wheel back on for now.
So, looks like I can hopefully file the burrs off and put a new 11-36 cassette on. The loss of 6 teeth shouldn't make too much difference.
Hmm, maybe I've realised the problem.
The original spec was an 11-42 cassette on Vision Team 30 wheels.
So when I got a good deal on the Pro Lite Revo 25 I got a cassette the same.
However, I've just realised that the big 42 apparently needs an XD freehub.
So maybe the original wheels had that kind of hub, but the new ones didn't.
In which case I'll need to get an 11-36 cassette instead.
I can't quite tell how a larger biggest sprocket would cause this problem, but this article states it quite clearly, that the 42 needs a different freehub. http://road.cc/content/review/170051-sram-rival-1
I can't actually see in either wheelset spec where it states the type of freehub though, so not sure how I could have known in advance.
What a dummy.
Depending if your worried about it or not, you can get a replacement freehub body for that wheelset. http://www.wiggle.co.uk/pro-lite-replacement-shimano-freehub-bodies/
Not too expensive, and for me would be the preferred route as I'd be worried about the burrs reappearing and me having issues removing the cassette later.
