11 - 34 rear cassette (11 speed)
jowwy
Can't spell, Can't Punctuate....Sue Me
Anybody know if theres any out there and if so where - without spending a fortune with interloc racing
Thanks
ps its to go on my new hi mod build for the alps, i want to try and run 50/34 - 11/34 so it ill give me 1:1 ratio for the climbs
Cubist
Still wavin'
Ovver 'thill
Shimano XT M8000 11-34
You'd need to be sure of compatibility, they say it's to run with HG11 speed chains.
J
jowwy
i'm running a long cage sram force rear mech and kmc 11 speed chain
Cubist
Still wavin'
Ovver 'thill
The KMC chain will do it OK I suspect, but you'll need to check the capacity of your mech. (although I suspect you already will have done if you already know the combination you want)
J
jowwy
mech is fine - just can't find the 11-34 m8000
Cubist
Still wavin'
Ovver 'thill
My mistake, it's 11-42.
It's looking like 11-32 in 11 speed, all the bigger ones are for 1* MTB setups.
How about a smaller chainring?
J
jowwy
got sram red upfront 130bcd.............could look for a 46/30 set-up of even a 48/32.....but don't know if thats a viable option on the sram red
J
jowwy
Try the Spa Cycles website. They are specialists in touring set-ups.
http://www.spacycles.co.uk/m2b0s0p0/Parts-and-Accessories
not got anything lower than a 35 inner for 130 bcd...............
J
jowwy
will keep an eye out for 11/34 cassette as thats the cheaper option if one becomes available
if not i will stick with the 11/32
si_c
Wirral
Ive seen that one.....but sram say its for 1x drivetrains only
Possibly, but is there a reason why it wouldn't work? I've seen a few people using them with double drivetrains, you'll likely need to adjust the b-screw, but it should work I would have thought.
J
jowwy
It might be down to wrap capability of the rear mech
16+25 = 41 and i think the sram force long cage is 39
But if i can get it to work my legs will thank me for it in the alps
