Probably would with some sort of Shiftmate on it, but for the price you might as well get the 11sp that just works, if available..Because a 10 speed cassette won't work with an 11 speed shifter?
have you got a link to the sram 11-34 11s????? not seen that one, seen plenty in 10sThere are 11-34 cassettes for the Shimano Ultegra 11s, it's listed as an option with Di2 group sets. It may be worth trying www.bike-components.de
Edited to add
SRAM has a 11s 11-34 cassette, as that's what I've got on my SRAM Rival on the Pro Carbon
in a word - NO..........and i'd rather support myself than local business, cause i'm sure they wouldn't support me if i was short on cash one day@jowwy,
Do you have a proper bike shop local to you, they usually have supplier systems that make searching for these things easy and 24-48 delivery (to the shop) and you support local business too. A quick call to your local shop would have this sorted in 5 minutes ready to collect shortly after.
Have you even had a quote? How do you know they are more expensive? Or do you mean there is no shop local to you?in a word - NO..........and i'd rather support myself than local business, cause i'm sure they wouldn't support me if i was short on cash one day
1.....dont need a quote, will get prices and do work myselfHave you even had a quote? How do you know they are more expensive? Or do you mean there is no shop local to you?
I'm all for open markets and efficiencies, but most wouldn't even consider popping into an LBS for a small component, very often they don't charge much more than wiggle etc, and will price match if you are a regular. You just have to ask.
Have you actually tried to get your LBS to price match Online pricing? If you succeed in that, then you'll actually be costing them money rather than supporting them, according to my range of LBS. That includes both a single small shop owners, and also a chain that is known nationally. Neither of them can buy in at the price that online companies sell for.Have you even had a quote? How do you know they are more expensive? Or do you mean there is no shop local to you?
Edited to add
I was wrong, the order spec was 11-34, but in fact it is a 11-32 SRAM.There are 11-34
Edited to add
I used a 40t in the alps with a road link and 46/34 front.....i might go back to that setup yetLooks like its not a R8000 cassette that's supplied in that option but a HG800 (see text description here: https://www.bike-components.de/en/Shimano/CS-R8000-11-speed-Ultegra-Cassette-p58015/ )
Here's the link to the HG800 11-34
https://www.bike-components.de/en/Shimano/CS-HG800-11-11-speed-Cassette-p58013/
I use a 11-34 (10sp Tiagra) on my CdF with a compact so I get a 1 to 1 and in that gear if the gradient is >20% its hard to stay upright at the speed it gives me - though I did find it easier to balance when it had panniers on.
On my Ti bike I have a 11-32 11sp and because the bike is a good 5-6kg lighter it is just as easy if not better on the 32t.
I've bought a road link to experiment with larger cassettes on the Ti bike for some long audax to Wales etc but seeing the 11-34 in 11sp I might give that a whir first
Would this 11-36 suit? A bit deeper gearing, but should work. Alternatively, fit a triple (50-39-30) and combine with your 11-32?Not seen an 11-34 cassette in 11 speed, but SRAM do an 11-36 for cyclocross. http://www.tredz.co.uk/.SRAM-PG1130-11-Speed-Cassette_81753.htm
You obviously havent read the thread......never mindWould this 11-36 suit? A bit deeper gearing, but should work. Alternatively, fit a triple (50-39-30) and combine with your 11-32?
