Nibor
Bewildered
- Accrington
11 tooth gears never wear out on my cassettes for some reason
11 tooth gears never wear out on my cassettes for some reason![]()
How much hassle is it to replace the 11-28 with a 12-30 cassette? The 5700 RD can cope with the 30t and the capacity required is only one more so chain would be fine. Going from a 28t to a 30t gives OP an extra 7%, which is quite a bit, and maybe is all that's needed.My argument is that 2 teeth is not enough to warrant the cost and hassle.
Same here![]()
I got a DX-10 with my new cassette seemes really smooth and are generally well thught of on line.Gonna have to check my DR capacity and chain. I have that horrible feeling that I'll need another chain, too.
Are the basic KMC DX-10 chains any good or should I go for something a bit higher up the chain (no pun intended)?
I would keep the same chain, unless you are running in big/big it should be fine, maybe fit a slightly longer one next time you need to change it.Gonna have to check my DR capacity and chain. I have that horrible feeling that I'll need another chain, too.
Mind you the 12-30 cassettes all seem to be 'out of stock'
Unless you have a triple up front capacity of your RD is not an issue/problem, and even then it's only a one tooth increase. Unless you know that the chain has had limited use, it's probably worth changing it when you replace the cassette as the latter will last longer (£30 cassette if you use the one @Afnug has linked) and a £15 chain).
@Nibor - why don't you link up with @MontyVeda - he could use the 11t of the last cassette you replaced.
What are your chainwheels ie how many teeth? This thread covered similar ground:
https://www.cyclechat.net/threads/lowering-shimano-105-gearing.198048/
and this thread covered new cassette/old chain issue:
http://www.cyclechat.net/threads/old-chain-new-cassette-question.197640
It has plenty f life in it I thought I may keep a spareUnless you have a triple up front capacity of your RD is not an issue/problem, and even then it's only a one tooth increase. Unless you know that the chain has had limited use, it's probably worth changing it when you replace the cassette as the latter will last longer (£30 cassette if you use the one @Afnug has linked) and a £15 chain).
