105 Front Derailleur wont fit
Dogtrousers
Kilometre nibbler
As a follow up to this last question lads the cranks on my new set up are 172.5 my old Claris / FSA were 175 do I need to adjust my saddle height proportionally for this
Which way would you adjust it? Down? (because at the bottom of the stroke the pedal is 2.5mm lower) or up? (because at the the top of the stroke it is 2.5mm higher).
Tbh I'd leave it where it is. Get settled in with the new stuff and revisit saddle height later if you find it necessary.
J
Jimmy Welch
Go
Good call
Ajax Bay
East Devon
You should adjust your saddle up 2.5mm as the distance you wish to maintain is the position of the leg when the pedal is at 6 o'clock (which with the 172.5mm cranks will be 2.5mm higher (cf BB)). This assumes you had your saddle at the 'right' height with the FSA 175s.
  • Like
Reactions: C R
J
Jimmy Welch
Yes cheers original was bang on from a full bike fit a couple of years ago
