U
User6179
15psi is not far off normal atmospheric pressure - in other words, there is no differential pressure in the tyre at all. Can we see a pic of you riding it?
Wheelbarrows run about 15 psi
![Smile :smile: :smile:](/styles/default/xenforo/smls/smile.gif)
I fitted a very cheap innertube in desperation before a ride yesterday. I was very careful to ensure no pinching of the tube and correct seating. However, no sooner than it had been inflated to 80psi the tube exploded with a six inch gash, blowing the sidewall of the tyre out and seperating the steel bead from the sidewall. This could have been dangerous at speed.
Brand new tyre too, so I'm down £40 due to a £1 innertube.![]()
you used an air compressor to get 15psi..?? Waving the tube around your head a couple of times would have been enough to get 15psi into it, surely...
I'd take it back to show them as you've said it was brand new. Unless there are signs of the tyre having been cut by a foreign object it sounds like a manufacturing defect which should be under warranty. I think the cheap inner tube is irrelevant in this case.Thanks for all the replies, I think in retrospect I can't really blame the tube, like another poster said, - there had to be another underlying cause.
I'll just suffer the loss, going back to the LBS and explaining I've fitted a £1 innertube won't get me anywhere.
This is silly imo, I've used £1 inner tubes with no ill effects to the tyres, not only, my lbs had for sale the very same make of inner tubes you can buy from the pound shop.Thanks for all the replies, I think in retrospect I can't really blame the tube, like another poster said, - there had to be another underlying cause.
Quite possibly because I put 105psi in my tyres! I am not sure that my wheelbarrow has such a low pressure as 15psi in its tyre.i speak english whats the problem this isnt the chinese cycle chat is it
why are you questioning me putting 15psi in like im a nutter
Cheers Ed
