Found a Bargain? Do Tell.
cyberknight
broady
Leicester
I don't need any wheels, but these 38mm 700c wheels are £97.50 a pair if you use the discount code '2020: https://www.superstarcomponents.com/en/essentials-road-2-2018-rim-clearance-wheelset.htm
Brilliant wheels - I've got 3 sets of the 30mm ones - as long as you don't mind a red rim.
Edit the above: I've a set arriving Monday.
Do they come with skewers and rim tape?
Dan Lotus
172.5mm and 165mm Shimano 105 5800 4iii crank arms for £205 - or if you go through TCB should weigh in at as whisker under £200.
VERY cheap, and seem to get generally positive reviews.
4iii 105 5800
Dan Lotus
Ravemen PR1600 - RRP £130, not seen it this cheap before @ £94.
https://sdjsports.com/cycling/accessories/lights-and-reflectives/front/front-bike-light-raveman-pr1600-rechargable-with-remote-1600-lumens-grey/?combination=22914_108933&gclid=Cj0KCQiAxfzvBRCZARIsAGA7YMwZV_-1-brdcDfxkTli_SzbU1Cp0ewdyIalI1A0XyJl6BmrueLkokoaAvQiEALw_wcB">Ravemen PR1600
LOVE the beam pattern of my 1200, plus the powerpack feature it has - handy flexible bonus.
And this one has a remote, so I will likely pop that on the hoods.
Going to buy a couple of extra mounts, so it and the 1200 are super easy to swap between bikes.
ONLY caveat I would voice, is that it states 'in stock', but then on the description states "Due Date TBD"
Having said that, ordered mine aftr Christmas, and arrived at work today, all appears to be mint.
