Below I just copy pasted a bit I find particularly interesting. There’s lots of other good tips though. The bit about a pace line being better than a blob is interesting. Although I think it’s most likely also a bit of an art to nail that one down.
But testing (
once again… Eric does the science here!) shows that a single-file paceline formation is significantly more efficient in Zwift than a small blob. My experience shows that if the front of the chain is pulling at 4 w/k, the 6th man will be ‘resting’ at around 2.5 w/k. The trick is to manage your effort… which is why we pull short turns of 20-30 seconds above threshold before falling back and “resting” at/around sweetspot. Done well, your team will move at a pace significantly higher than you could possibly achieve otherwise. My latte team (basically a C team) moves at a consistent 4 w/k on the front.
In a paceline, situational awareness is the most important factor – know who is in front of you and who is behind you. Stay in the draft of the person in front – but be aware if a split is forming behind. When you are on the front you are expected to maintain race-pace (either w/k or kph), and when your turn is done – drift back. As the person ahead of you moves up the line be aware you will need to step up power ½ w/k. Be aware… this won’t work without some form of team communications.
As a team rider your job boils down to the following:
- Hold the line in front of you. Don’t drop back more than 5M… don’t surge ahead.
- While on the front maintain the target speed as long as you can knowing this is a sustained race – 20 seconds is perfect.
- When your turn is done soft-pedal for a few seconds and allow your avatar to drift back. Pay attention as you drift – coast for too long and you will be spat out the back.
- When on the back rest…
- As you move up the line listen for the front-rider’s count… when they finish their turn, step up your pace just a little
And thats it. Now you can TTT with the best!
