That was interesting, not a lot of difference between the Neo & bkool.
I do have a theory, that depending how close your body weight is to 75kgs (the figure that most trainers calibrate too) depends on the accuracy, ie. I’m a 98kgs rider and I found the bkool numbers way out but where as Paul is 77kgs and we were both scratching our head and concluded that the Neo & the bkool is not that far out...
First of all, having seen the inner bits of the Pro unit, it doesn't look like you can expect super precision, so there's probably a fair amount of variance between the units to begin with.
On top of that, some of us had Bkool dial in and changed our unit configuration.
The result after 3 config changes on my unit, seems to be that it gives me much more realistic avg. watts in BSim, but unfortunately with a wrong distribution (too little going up and too much going down).
The result in Zwift is that I cannot use the Pro as a main source. Zwift is probably expecting a "standard" Pro, not a realistic one
. I have to switch to my lightest gear (34/28) just to be able to keep an acceptable cadence at 0%.
I recently aquired a 4iiii power meter which is now permanently on my commute bike, and I have been using that as power- and cadence source for this- and last months Zwift rides. The Pro behaves very nice when it just needs to change resistance.
