Zwift Chat
JuhaL
Start TR first, minimise the screen so it appears on the bottom of the screen. Then start Zwift, disable controllable turbo in setup page. Select ride as normal. resize TR to suit
Starting pedalling:okay:
Exactly that’s the way i thought it should go. I think it’s less boring to do workouts on TR when you can ride on Zwift virtual world at a same time.
Marino.g
Taunton
That’s what I like about training peaks.
Your scheduled workout for the day is listed automatically on the Zwift workout list, you select and it’s all there and linked to your companion app as well, no messing.
It’s like doing a Zwift workout with the info on the screen but you’ve selected Your own workout planned by your coach.
Whorty
Gets free watts from the Atom ;)
Wiltshire
Bridgy good luck mate. Don’t over think it bud.Really like the mike Tyson quote:
“everyone has a plan until they get punched in the mouth!”
Screw the weather. Don’t take liberties on the bike and bury yourself the last two mile run! 👍👍👍
Calm (ish) here this morning. Was awful during the night but hopefully blown itself (mostly) out :okay:
Edit : just saw the race was canned ... 😢
Whorty
Wiltshire
Id go for it Tommy in cat A. It will make you stronger in the long run
Ride with faster riders if you want to be faster.:okay:
Hell I can hang in with 'A's on a pure flat course:laugh:
Try a Hare and Hounds @<Tommy> in A cat .... they will be pushing hard but not actively trying to drop you so you should be able to hang on for a good time. I join B's sometimes to see how long I can hang on - my best is 12 minutes.
JuhaL
Tomorrow i try to ride on Zwift and Trainerroad simultaneously, it suppose to be easy.
I manage to do this but not away i thought. I thought that i can pair my devices using Ant+ connection with both apps but it didn't go like that. I paired my trainer and hr sensor to TR on ant+ and on Zwift i need to use bluetooth because Zwift didn't found any devices on ant+, i guess that is the way how ant+ works. I have try to avoid to use bluetooth because ant+ is worked well so far.
