Well I can assure you that's exactly what it looked like from where I was!I can assure you I wasn’t behind you saying “ go on just a bit more “
I haven't asked mine yet
HID has mentioned a holiday next year to tenerife I said 2 weeks 1 week for cycling and the other week for family she said that's fine![]()
Let’s see where we are if we make it to Ventoux this year![]()
I’ve already asked my boss for time off![]()
Well you have the law of averages on your side if nothing else!
i only want to go to try and keep you 2 apartPost surgery mate so the only way is up
And I will take the law of averages![]()
Cheers Andy I'll probably take you up on that offerDean, stay in the South, much drier and warmer. If you want routes ive done let me know and Ill sort out for you. Or if you want to go with Tenerife bike Training, I'll make introductions for you.Great guys Alberto, Marcos
i only want to go to try and keep you 2 apart![]()
The climbs seem to do that![]()
bob ?https://www.ebay.co.uk/itm/Ridley-N...h=item3648629762:g:70IAAOSwSSNbnXEQ:rk:5:pf:0
dont say age and not disc brakes and maybe dear but i like it or
https://www.ebay.co.uk/itm/2018-Cer...=item36485bd99d:g:0-IAAOSwolpcSau7:rk:12:pf:0
Been there done that. Hope you got the right Loctite type, so you will be able to dismantle the bottom bracket again,I just worked with cyclist dear friend called creaking noise. Tomorrow i find out did i do work for nothing. I removed bottom bracket and cleaned all the parts and frame and put it back with little bit loctite.
I used Loctite 641 which is medium stregth retaining compound. It`s been worked well but probably need to redo that treatment occasionally. These indoor trainers stress bottom brackets quite a lot so i am not suprised about those creaking noises.Been there done that. Hope you got the right Loctite type, so you will be able to dismantle the bottom bracket again,
