Cycling_Samurai
Replace several coffee mugs with small cheap plain ones.
That's PROPER evil 🤣🤣Reset all the mobiles to factory settings.
Nah, that's not evil...That's PROPER evil 🤣🤣
Reminds me of someone who turned his P reg into a brand new R reg when they came out one August. Only took a strip of insulation tape.Change the number plates on their car... and wait, possibly a long time.
put the loo roll on the dispenser the wrong (according to Mrs Poley) way round " it must have been a break in dear because I would never.. ever do that"![]()
Clearly you don't understand what setting to factory settings does. Where changing the language can be fixed.Nah, that's not evil...
Changing the default language to Malay (for example) would be evil
Top tip: check the phone owner doesn't speak Malay, if they do switch to Ukrainian.
I'm putting waaaay too much thought into this...
Nah - I would - all clock MUST show the correct time so I compare them to an accurate time source every few weeks and adjust accordinglyAlter the central heating clock ... nobody will know how to change that back.
doesn't everyone???????????![]()
Yes I have. It can be fixed. Try restoring your mobile to factory settings and tell me how you fix that.Have you ever tried to use the menu on a phone in an non-Roman alphabet?
Mate, that is just not right.Replace their real ale with lager and vice versa depending on house you break into.
