Pale Rider
Forecast is all over the place, although it's improved a bit from the last time I looked.
See you all in York.
I wonder if it's possible to miss out part of the stiff climb - and busy main road - after South Ferriby.
@Buck may recall two cyclists in front of us took the minor left fork on the outskirts of the village.
Looks like there's a track of some sort to South Ferriby Cliff, and Barton Cliff, where there's a car park.
It must be ridable from there past the nature reserve at Far Ings onto the minor road which takes us to the bridge.
https://binged.it/2eHO72R
I thought about Buck's report of the first climb being 12+% and from my recollection, that seemed wrong so I just checked the climbs on my OS maps ...
The first climb (Flixborough) was about 600 metres at 5%.
The second climb (between Thealby and Winterton) had a 200 m stretch at about 10%.
The 3rd climb (South Ferriby) had the steepest ramp - about 250 metres at just over 12%, which was about my limit on my singlespeed's 52/19 gear - much longer or steeper and I would have had to jump off and walk!
After the bridge, there was one long easy drag/climb (from Raywell House) - about 4.6 km at 2.2%.
I think the % is academic as it's whether you get to the top or not
I may have got the order of the climbs the wrong way around but I was sure it was the first that got steeper the further up the climb we got?
I rechecked my Garmin file and cross referenced to the Strava segment and it does have a ramp in it up to 14.4% (not that I'm saying this is totally accurate!).
With OS and segments, the % calculated is always an average so belies elements within the section - especially where you get a false summit and/or an exponentially increasing gradient.
Anyways, we all made it safely and enjoyably!
