SkipdiverJohn
Deplorable Brexiteer
- London
I was under the impression that most aluminium alloys fracture or shear rather than distort; guess I was wrong?
There's various types of aluminium alloys with varying degrees of hardness. pure aluminium is very soft, relatively weak, and not much use for structures. It only becomes useful once you start to alloy it with other things to alter it's characteristics.
For example, my Land Rover body is made of an Aluminium-Magnesium alloy known as Birmabright, which is considerably harder and stronger than pure ali. You can still dent or crease it fairly easily though compared to steel.
What you get is plastic deformation as you load the alloy beyond it's yield point. if then left alone, the material will stay together, but in a weakened state. If you try to bend it more though, or bend it back in the opposite direction, you start to compound the structural damage then it will often shear off, not as a result of the original deformation, but the subsequent attempts to put it right.
The bottom line is if you dent an alloy bike frame the best thing to do is leave it alone and live with it, attempts to reshape it are likely to make matters worse.
