Alex321
- South Wales
I don't actually see much wrong with that one. Yes, it is very short, but it does provide a legal shortcut for bikes.
Perhaps try putting a bollard in the middle of a road and see what drivers think of it?
Looks like plenty of space still
Bollards are lower than handlebars. I pass a number on local cycle routes without any problem so long as you ensure pedal clearance.OK, put a bollard in the middle of a wide road. See how you get on.
Totally different matter is an A frame barrier that a straight bar bike will not get through without wriggling the bars through the opening. My road bike fits through okay. I mention them as its the only place locally I have found a cyclist lying on the ground as they had misjudged the A barrier and probably were going a touch too fast.
I rode it this spring and it was much better. The time before that it was as you say, like the RAF had used it for bombing practice. If you go on Google street view it still looks fairly flat but I think it gets used by the big trucks heading to and from the industrial sites along that stretch. So it may not stay flat for long as its only a gravel track.
One of my favourites in Ipswich - directing you off the road and almost straight into a lamp post & road sign
I've got to say that there is an excellent cycleway path near Knutsford, where the A556 got decommissioned, now called the B5569.
Except
(1) it goes to nowhere, apparently its termination justified because they did a survey of cyclists on the 556, found none (unsurprisingly, it would have been suicidal) so it could justify not spending the money to link Altrincham to Knutsford which would actually be useful.
(2) As your pic shows, you have to give way at every single driveway (!) making it functionally useless along what is now a very quiet road anyway for the bits I ever ride.
(3) At the far end at least, it's used to be loose gravel surface, maybe that's changed.
I ride the road.
You can get to Altrincham/Bowdon via Tom Lane. Then you have to negotiate the traffic lights on the Bowdon roundabout. This is the connection to Altrincham.
Info:
"the status of the footpath crossing the M56 via Tom Lane being upgraded to allow use by cyclists as well as pedestrians and would be diverted to join the re-modelled Bowdon Junction."
"There is a route from the B5569 through to the Bowdon Roundabout, it goes down Cherry Tree Lane, Tom Lane and Yarwoodheath Lane, joining the mini-roundabout, where there is a path and ability to cross safely once vehicles are stopped by the various traffic signals. "
