Twilkes
After creaks and clicks, I removed the SRAM Rival crankset from my Cannodale to find the following wear:
* The drive side on the right, where there is still black surface, is the least worn, with a smooth surface left to right and a width of about 5mm; the non-drive side on the left has a definite ridge on either side that I can feel with a finger nail, and is 6mm wide:
* On the other side of the spindle, it's the opposite - drive side has a deeper ridge and is 7mm wide ; non-drive side is reasonably smooth and 5mm wide,
* Might be able to see the extent of the drive side ridge in this photo:
So what could have caused this wear - is it just worn bearings (one of the old bearings could slide loosely across all of the spindle, the other was still fairly tight) or could it have been installed incorrectly in the first place? The LBS had used two washers and a wavy washer which the SRAM guide says aren't necessary for BB30 installation, but it would have added 1-2mm to the non-drive side at most so I'm not sure how much difference that would have made.
Fitting new bearings and new crankset tomorrow so hoping that the frame wasn't affected by any of this, I can't see any particular wear in the shell or the outside of the old bearings. At least I've got the tools to maintain it myself now if any noise comes back.
