Work stand
DEFENDER01
Essex
I can see the concerns if you have a carbon frame but the clamps are V shaped for a reason to put the clamping force onto the outer of the tube which is the strongest area.
So i can see no problems with using the top bar on a steel or alloy frame.
A MTB is a lot heavier than a road bike and clamping the seat post on one of these does put enormous force on the work stand pivot head. :popcorn:
alicat
Staffs
I have a Revolution Tune Up Stand from Edinburgh Cycle Coop, which looks remarkably the same as the Ribble one in Smokeysmoo's link but dearer when not on offer. If it broke I would buy another one straightaway.
Just a thought to the OP, if you have a garage/shed that you work in a rope or hook on the rafters or bracket on the wall can be just as good as a workstand and a lot cheaper.
Drago
I've seen several frames damaged in this way. Once you've seen it with your own eyes (and then gleefully chopped out a cross section of tube to see how thick the frame material is) you won't do not again to one of your own steeds.
youngoldbloke
I have a Revolution Tune Up Stand from Edinburgh Cycle Coop, which looks remarkably the same as the Ribble one in Smokeysmoo's link but dearer when not on offer. If it broke I would buy another one straightaway..
IMO it is the same. I've got the Ribble one and highly recommend it. As far as I can tell it is sold under many different names (in fact the box mine came in from Ribble had Raleigh branding on it) often priced a lot lot more (see http://www.winstanleysbikes.co.uk/product/64832/BBB_BTL36_ProfiMount_Bike_Repair_Stand_2977453601?gclid=CJD6jqbOqscCFYbItAodFysKWg for example). But I did buy a separate tool tray from Edinburgh Bike Coop - which I seldom use :smile:
Domus
Domus
Sunny Radcliffe
Many thanks for all the replies,leaning towards the Ribble one.
Last week whilst fitting mudguards and new tyres I had it cable tied to a 4x2 gripped in a Black & Decker workmate. The wheels were just off the floor and a little too wobbly for my liking. :stop:
alicat
Staffs
If you do get the Ribble/the same with different branding one, I echo Youngoldblokes not to bother with the tool tray. It's in the wrong place and more trouble than it's worth.
Yeah FWIW I've never used a tool tray with mine either, but everything in my shed is virtually within arms reach so I never saw the need for one.
DEFENDER01
Essex
I would say the problem is people think they should be adjusted tighter than they really need to be.
Many times i have seem people tightened things up to the point of stripping the threads.
Common sense is a thing of the past these days sadly. :popcorn:
mybike
Grumblin at Garmin on the Granny Gear
DEFENDER01
Essex
Well i did try clamping to the seat post as suggested and i could see the top V clamp support twisting.
I wouldn't feel happy working with it in that position very unstable.
As long as a bit of common sense is used when tightening the clamp i see no reason why the top mount is not a good mounting point.
Anyone that has tightened the clamp to such an extent as to damage the top bar shouldn't be working on bikes. :popcorn:
potsy
Rambler
My Armchair
I too have the Ribble one, it can be a bit creaky with the heavier bike in it but is fine.
I usually clamp the frame as the faff of removing lights/bags from the seatpost is too much, there again I'm not a meathead like Drago so a delicate touch is all that is needed :whistle:
DEFENDER01
Essex
Just to make sure i dont scratch the paint decal i use a piece of soft material between the V clamp
