Wobbly headset.. Help!
@Andy_R
"When you do up the top cap bolt you aren't trying to "tighten" it, you're aiming to remove any slack. "
Wow. That is described perfectly to a layman like me. Thank you very much. Can I please ask, can the headset get loose over time (six months) through general cycling, hitting road bumps etc? Are there parts of a bicycle need tightening up again over time?
Thanks for your time.
Rack mouting bolts can sometime back out by a mysterious phenomena called precession. It appears as if someone has undone your bolts. My solution was to fit anti rotation ( star) washers. Most other vulnerable threads have the thread direction reversed to avoid the problem.
Ajax Bay
East Devon
Rack mouting (sic) bolts can sometime back out by a mysterious phenomena called precession.
BS. "a mysterious phenomenon called loosening" - FTFY Michael. "Left pedals, right bottom bracket (BB) bearing cups, and freewheel cones": yes.
More on precession (Jobst Brandt): https://www.sheldonbrown.com/brandt/left.html
