Why ?I only use 40psi on the road.
Why ?
fat tyres and low pressures = no grip
..most of the time.
erm off it is the mtb section after all
are you talking on road or off road?
erm off it is the mtb section after all![]()
Not much lower but around 35, maybe 30. Might change with 29ers and on hard ground no need for the lower pressures.Why ?
..most of the time.
@VamP do you run tubeless at those pressures and isn't that just so low as to create a lot of drag, I notice it at 30, it has to be real muddy to go that low for me?
Well in that case I have to strongly disagree. Lower pressures give more grip and better rolling resistance. The only reason to run high pressures off road is in very rocky environments to protect against punctures.
