Rob3rt
Man or Moose!
- Manchester
Not here, it isn't!
That's why the pro's pull on gilet's in the Tour, Giro, Vuelta etc
Not here, it isn't!
That's why the pro's pull on gilet's in the Tour, Giro, Vuelta etc![]()
It is pretty specialist, used to generate heat in humans and hybernating animals. Not entirely sure why anyone would want to burn it, but mimi's :P does suggest that she is aware of this."brown fat"???? never heard of that before. "is activated" i dont understand it at all![]()
Hi.
Just a question.
Does riding in winter / cold temperatures give any extra phisical / fitness benefits than if you ride in more mild climate conditions?
For ref cold Id say sub 7 degrees. Mild over 10ish
Sounds horrible, theres not much worse than cycling while feeling like you're freezing to death.It depends a lot of what kind of riding you're doing, too. If you're riding on safe roads - as in there's nothing majorly slippery on the surface - you can push on and keep your body producing warmth, so you maintain a fairly steady temperature. If you're riding a mixture of safe and slippery roads, you get times when you're pushing on and times when you're having to take it slow, so you're liable to be too hot in one situation or too cold in the other.
My worst experience was mountain biking on Friday. I climbed over 800m, and I was pretty warm on the climb in just a thin baselayer and windstopper jacket (undone), mitts and nothing warm on my neck and head. By the time I'd done the descent into a northerly wind, I was so cold I literally couldn't feel my fingers and my stomach muscles were cramping. I really needed to carry a warm jersey, buff, hat and winter gloves to put on for the descent.
So, from my experience, the only option if you're doing varied rides in cold conditions is to be prepared to stop often and add or shed layers.
Hi.
Just a question.
