For water fed poles deionised water is recommended.Yes but you need to use Pure Water or you will have dirty windows with tap water.
Anyone tried them, do they work? Ones like these off of Fleecebay Ebay Link I know in town they use ones with jiggle valves in or low pressure pumps in the back of vans. Our upstairs windows are awkward to get to as they are above a porch/bay window so this looks like a solution.
We had those on the back of the house but have just changed them for normal windows as the seals started to leak which allows water into the house.Doesn't everyone have windows that turn to let you wash them from the inside?
I did wonder about that as we live in a hard water area, I wondered also why the profesional kits are nearly £1k but if they are pumps & di-ionser units that explains it.For water fed poles deionised water is recommended.
I'm not convinced with the deionised water cleaning... I had a guy who uses that method but the windows didn't look any cleaner after he'd cleaned them. Plus he eventually proved unreliable (and frustratingly dim) so i sacked him.Yes but you need to use Pure Water or you will have dirty windows with tap water.
My widow cleaner is English.Oops think I’ve got if wrong.
They're a pane..What's wrong with dirty widows?
Is that a job, going around cleaning widows? seems a bit sexist to me, who cleans the widowers?My widow cleaner is English.Oops think I’ve got if wrong.
If ordinary tap water is used instead,it leaves streaks andwater marks,but I've seen windows cleaned with deionised water and they looked streaky. As I said earlier,the lad who cleans mine uses a water fed pole, but i'd prefer it if he used the old fashioned ladder and bucket method as when on the ground you can't fully see what's on the windows and their frames.We had those on the back of the house but have just changed them for normal windows as the seals started to leak which allows water into the house.
On the subject,i've never seen a female window cleaner. No I have actually! My daughter gave me a lift sometimes for pocket money during the school holidays. I lost count of the number of times I caught her skiving and on her phone.Is that a job, going around cleaning widows? seems a bit sexist to me, who cleans the widowers?
