Will this change my chain line
andsaw
Im thinking of fitting this https://praxiscycles.com/conversion-bb/ to my Cannondale SS Evo 105 in place of the prone BB30 pressfit bearings, if i was to fit this and add a 105 compact crankset would it throw the the chain line out at the front mech, and what would i have to do to rectify it, would there be any other problems i might encounter, my LBS would fit this as i haven't the tools for this, has anyone done this to their Cannondale or other brand.
U
User6179
A bb cant change your chain line , it is fixed by whatever crank you use .
Kbrook
I've done exactly the same with my Felt. Changed the BB30 to a praxis works, and the chainset from FSA to Shimano. Rest of my bike is 105, no adjustment needed, no more creaks!!!!
I also had worries about chainline as you are going from internal to external bearings, but trust me its not an issue.
andsaw
andsaw
How much if any, improvement did it make.
ColinJ
Puzzle game procrastinator!
I heard quite a few creaking bikes on Sunday's audax ride. It was annoying enough to just hear them down the road from me, so I wouldn't like my bike to be making those noises!
Still, it seems bad that a new design of BB is prone to these problems so another 50-odd pounds needs to be spent to fix the problem ...
Kbrook
Andsaw... Total improvement went from a creaking bike to non creaking bike. Other than that no difference
U
User6179
That's not true - you can get different length spindles on BBs, so of course that changes the chain line. A triple chainset needs a different length to a double, for instance,
Yes but not on the type of BBs the OP is talking about as the actual BB is part of the crank .
Kbrook
Neither BB30 or Praxis converter has the BB as part of the crank.
