ThanksAss saver will also not stop your jacket from getting mucky. You need full mudguards if you want to keep the back of your jacket clean.
It does..........thanks.If your wedge bag has a strap that goes over each seat rail individually and Ass-Saver should work OK.
Thanks but there is absolutely no where to fit that on my Defy with the wedge bag on.A Zefal Swan is what you need. Excellent piece of kit in my experience.
Review here: http://road.cc/content/review/174324-zefal-swan-road-rear-mudguard. Not sure where they got that RRP from. Currently out of stock at Tredz so £9.89 at Wiggle (plus P&P or something worth a few pence to avoid postage).
Don't bother with the matching Croozer front mudguard if you have a beefy downtube as the rubber band won't fit.
Probably..............but TBH I'm not worried about that............just my shiny new jacketDoesn't it end up above the pack thereby directing even more water at it?
those bar ends look like they are on the wrong sidesView attachment 115650
I've got whatever the Planet X version is called and swapped it between bikes till I put the Road Racer 2's on the road bike.
You'll see it above on the hybrid (with Topeak bag underneath) as the Crud guard doesn't quite stop spray coming up off the back wheel if it gets a bit messy. I still get muddy, but not as bad as I used to.
Simple answer - it will work up to a point, but if you like clean clothing then the only answer is full mudguards..
Broken hearted.............I went out wearing my smart new wind proof jacket and GOT SOME MUCKY SPOTS ON IT !!!
Those "ass savers" seem a good idea but looking at the web site I get the impression that they won't fit if I have a saddle bag attached.
Has anyone tried it ?
Failing that I may have to leave my jacket in the wardrobe
@Dave7
I use an SKS S Blade (with 35mm tyres) on my CX - I ride filthy lanes and some light, equally filthy, off road and get not a jot of said filth on my jacket.
I think the reason it works is that it can be set very close to the tyre and that helps no end with stopping the spray coming up/
Fits on and off in a few seconds too and looks much more discreet than that hideous Zefal thing.
Anything on the front ? Thinking for my own CX when I got my c2w through.
Mind you looking at it, I would not want to be following you
