chriswoody
- Northern Germany
As I mentioned in my first unhelpful post, I agree with you that the problem is the air is escaping from the base of the valve. Looking at your photo, where you have marked the base of the valve with the blue mark, could this be what you're looking for to block up the hole there?
It's a DT Swiss Asymetric rim valve adapter, designed to plug up the hole marked in blue on your photo.
https://www.chainreactioncycles.com/ie/en/fsa-asymmetric-rim-valve-adaptor/rp-prod201305
Used in combination with the valves you have, it should make everything airtight with the rims you have.
