fair weather cyclist
Problem with tubeless conversion here.
I'm looking for possible explanations and solutions before I bring the wheels to my lbs.
I am trying to convert a gravel wheelset to tubeless. The wheels are tubeless compatible, meaning the rims have hooks but you have to put tubeless tape.
Here's what I did, chronologically:
- removed the yellow tape
- cleaned the rims. I used a microfibre cloth and wee spray of wd-40, cleaned it nice and then dried it off completely with paper towel.
- installed muc-off tubeless rim tape (to be on the safe side I did 2 rounds of tape for each wheel)
- installed the tubeless valves (also muc-off)
- put the tires on
- sprayed a bit of soapy water to help with the seating
The tyres don't seat. I tried with a track pump, nothing. Then went ahead and bought a tubeless air tank, still nothing.
A lot of air seems to be coming out of the tubeless valve, then I had this thought: is it because I have asymmetric rims? The wee rubber ring that goes around the valve does not sit around the valve hole.
Can this be it? My thought is it shouldn't matter because there should still be the tape preventing air going out.
Can it be a combination of a dodgy taping job plus the asymmetric rims? Another suspect is the use of wd-40. Maybe not the best thing to use and it's making the tape not stick nicely? I don't know...
It's my first tubeless conversion so I'd be surprised if I didn't f**k up something at some point.
I can take photos if you wanna see it.
- put the tires on
