3 sets of suicide levers spotted.....they won't last long in the wild![]()
I like my suicide levers. They don't do much but they make me look brave!![]()
If the handles are not to sloppy they can be quite useful
TBH they're sorta like the main levers only a bit sloppier and a bit less useful![]()
Looking through the vintage section of Ebay I came across a photo that explains why old bikes are so much nicer than new. Turns out it's got less to do with craftsmanship than it does good husbandry.
You see, once built, vintage bikes are free range and grass fed!
Whereas with older brake levers you could never brake from 'the hoods' you might as well have started blowing in front of you to stop given the leverage achieved by that technique.They worked OK if your wheels were very true, so you could keep the pads close to the rim. There was just enough travel in the levers to apply the brakes then. They were killed off by Shimano moving the pivot point of their "aero" levers so they could easily be applied from the hoods. These days, you virtually never see professionals riding on the drops; they set the bars as low as possible and ride on the hoods. They might as well have bullhorns, except they're not allowed in mass-start races.
I can't find any pics of it. I doubt he's old enough. Are you sure you're not thinking of interrupters aka crosstops aka cyclocrossers?Didn’t ThomasVouclar ride with suicide levers in Paris Roubaix
