Rohloff_Brompton_Rider
Formerly just_fixed
i agree the bike looks great.
As for the front wheel slipping out from under you and needing the rear brake, well you should get pretty good feedback of your traction via the drivetrain in order to make some educated speed modifications before putting yourself in a situation where the front end is likely to go.
Rear traction may not always be a good indicator of whether the front wheel will slip; the rear wheel is not able to turn. So locking up or resisting the motion will only result in a skid, which can be easily controlled and rolled out of. If the front wheel locks up under braking or slides due to lateral movement it can mean the bike slides out from under you.
I just meant I couldnt tell exactly what the point/opinion/argument you were expressing meant in context.Well spotted! They were having their weekly clean!Now that's extreme on a new level![]()
To add to the brake debate, I did take the rear brake off but found there just wasn't enough stopping power - perhaps I use the rear brake too much.
Nice ride, now turn it around and take a proper pic please![]()
I thing we need to see a picture of that frame after dark...
