amaferanga
- Bolton
I am curious as to why so many people say that the calories I am using are inaccurate though? Surely calories burned are a mathematical equation? My HR monitor takes into account my gender, weight, height, resting HR and vo2 max so how can people say this is widly inaccurate? Surely this has got to be more accurate than trying to say so many calories per mile which does not take into account the weight, gender, exhertion or fitness level of the cyclist?
Calories burned on a bike relates to your power output. As has probably been covered on this thread already, the energy used to propel the bike (in kiloJoules) can be equated almost 1:1 to the kCal burnt (assuming human efficiency of 25%). So if you ride at say 200 Watts for 60 minutes you'd 'use' 720kJ of energy and burn approximately 720 kCal. Environmental conditions can influence the 1:1 relationship, but in the real world you'll probably not get a closer calorie estimate than you'd get from a powermeter on your bike.
Unfortunately power output doesn't really correlate with heart rate in a way that allows a simple mathematical equation. If it did then no-one would waste several hundred or even thousands of pounds on power meters - they'd just get a £10 heart rate monitor instead. Manufacturers such as Polar and Garmin use various algorithms to estimate calories burnt, but they simply cannot be accurate due to the fact that there's no direct correlation between HR and power.
Unfortunately again, most websites and HR monitors seem to overestimate kCal burnt, which is why many people are recommending taking a conservative ballpark figure instead of the ludicrous figures thrown around on this and other threads.
Cheese is one of my biggest weaknesses. The higher fat the better, on a crunchy baguette...... feeling hungry now!!!
I lost about 15 kg, want to shift another 8 but nothing doing
