People talk about compact chainsets as if they are for wimps, but all my racing was done with a top gear of 52x13, which is 108 inches and was the standard set up for both amateurs and professionals for years. Even using a 48t outer ring (For those who don't like the jump between 50 and 34) will give you a top gear of 117 inches when used with an eleven tooth sprocket. As has been said, the move to 10 and 11 speed cassettes with the vast range of ratios available has killed off the triple setup on new bikes.
