JamesMorgan
Some of the respondents on this thread seem to be confusing cycling up hills in a low cadence because you have run out of gears, to believing that this is in some way optimal. If your gears aren't suited to your terrain and you have to grind up the hill, then yes you have no choice but to do it. Personally I prefer to fit appropriate gears. Most of my rides rarely encounter gradients more than 10% gradient. I use a 30 (chainring) - 32 (cassette), which at a cadence of 90 gets me up at around 7 mph and uses about 350W. Seems to work for me - I can't see any benefit in pushing the same power output at a lower cadence.
