2000 is very little for a 19stone man. How did you arrive at that figure?
I agree with this. Cutting calories by too much can be as harmful to weight loss as not cutting them enough. If you've been doing it for a while, it will put your body into starvation mode, which means your energy levels will drop, and you'll find it harder to be physically active (your body's way of forcing you to burn less calories). Technically, you shouldn't go into starvation mode at 19 stone, but everyone is different, and if you've been on crash diets in the past (5 - 8 pounds a week is a crash diet), that will have had a negative impact on your metabolism.
The big red flag to me was when you said you're getting hungry 20 minutes into a ride. If you were eating enough (or, as has already been said, the right kind of food) that wouldn't happen.
In your position, I'd try increasing calorie intake by 500 a day for a couple of weeks, and carry on with your current activity. If the weight starts to drop off you, which I think it will, you'll know you're on the right track. And if you're not on the right track, 2500 calories a day isn't enough for you to gain weight at your level of activity.
