Chrisz
- Sittingbourne
What is the rationale behind compact chainsets?
I've done similar with my bikes I got BBils to fit a 39/53 to the kinesis and my Bianchi has the compact (36/50). My Sirrus is a 30/42/52 and once a year I'm in the granny and to be honest I like to use the 42/52 more than the compact; 36 for me is too low to cruise on the club run and I sometimes spin out in the 50. So hopefully the 39/53 will suit me and if I find myself struggling on hills I'll change the cassette for a 12-27 or something.gavintc said:I have a normal chainset on my commuter and a compact on my good bike. I find for most riding the normal chainset suffices and I like the narrower gap between 53 - 39. A quick change of front ring does not demand necessarily a change up at the back. My good bike was specced for sportives and when I was less fit. I have pondered changing to a normal chainset, but find that every so often I need the lower gears 34-25 when grinding out a steep hill. I have raced the compact and not been bothered by the lower gearing but find myself not using the bottom range of 34 for most riding.
In conclusion, I think I need the bottom gears when doing sportives. But, I like the less sharp change between 53 and 39. So, I will probably stick with the current option.
stephec said:Re the debate about the wide spread between 50/34 as opposed to 53/39 - why not have a 50/36 as a compact then?
Big John said:I did a race and realised you can't race on a compact 50/34 as you do miss that top gear.
